What do u think of vauxell tigras?
Went in one today, presuming you mean the new one?
Sister got one on Saturday, soft top. It's alright, but a bit ugly.
The new one is not for tall people
I'm 6"1 with short legs. Only a 30" inside leg - consequently all of my height is in the body.
I cant get my head inside the new tigra, only way for me to drive one would be to peer over the windscreen, effectively sticking my head above the roof line :/
Know nothing about the new one other than it doesn't look bad for a small, er, coupe thing.
The old one is Corsa based, uncomfortable and generally horrendous.
Have only driven the new one. Looks reasonably smart, interior is typical vauxhall tack though. The one I drove was particularly scruffy even for a 5000 mile rental car.
Chassis is not particularly stiff, worse than other convertibles I've driven. Engine/gear box were ok though, suited the car well.
Please Please can I be the one to pull him up for a spelling mistake? :confused:
You'll need to be buying a good one if you do, and there isnt many of them around!
why? whats wrong with em? this one is 1.4 which i dont wanna go to 2l anyway and looks sporty and is cheap...
Whats right with them?
Assuming you are talking the old one, its based on the utterly shoddy "Corsa B", the build quality is terrible, the handling is terrible, the quality is terrible.
Its cheap because ITS CHEAP. Built cheap for idiots who buy curvy "cheap" things because they "look" "funky".
Utterly terrible cars.
well they look good:D
