XSPC Edge CPU Waterblock -- Set to topple the FuZion?
HeX
HeX
20 Jun 2004
Huddersfield, UK
Huge in depth look here: Click Me
Seen them retailing for ~£30! So if it is a FuZion beater its a great price!
very nice.. will definitely pick one up if I can find one for that price!
This looks good. I would prefer a delrin top though. Seen them for £34 at loads of places so cheaper and better than the D-Tek Fuzion v2. I will be changing my pump soon so i might get one of these to replace my MP-05 Pro LE while the loop is split.
That's a good review site too. There's not many that specialise in watercooling. Good find.
Got mine today minus the installation manual, has anyone seen a pdf or review that talks about installation? just so i can keep myself right.
I'd assume its the same as the X20 Delta, there is a manual for that on the XSPC website.
I've still not got it installed, i cant make my mind up on placement of the 120.3.
Was planning on having it on the back with a radbox but it blocks the psu socket... might have to cut some holes in the case.
Going to install mine in the next few days.. i didn't want to be without net while i cut up my case and got everything installed and would have rushed it so i've bought a laptop and will take my time with it now.:)
Any update on people getting this block?
Would love to know if they plan to make a delrin topped version.
Performance seems excellent! :)
gt
AFAIK a derelin version is in production, don't know when its meant to be out though.
The FuZion V2 does perform slightly better, but it is massivly more restrictive than the EDGE.
