Just been given 10 x 36gb scsi drives...
26 Mar 2007
Nottinghamshire
All are working fine and I'm wondering what to do with em.
I'd like to try and utilise them in my main rig in a RAID config. What are my options here as obviously my comp does'nt have any SCSI ports, can I use them or are they dustbin fodder?
Any help appreciated...
If you want to use them then will need a SCSI RAID card. Depending upon your computers main board then will depend upon what would be a good choice.
No point in putting on a normal PCI RAID card.
Im on an MSI P35 Neo2 FR, any recommendations?
What the maximum no of drives I could get on a RAID 0 config?
Ive got 3 18.3gb ones, they are 7200rpm and really really really really noisy. I found them in a Proliant server in the tip :)
a place I worked at a few months ago tipped 35 servers... yes 35!!
I wanted to ebay them or give them to charity.. do something with them.
all between 3 and 4 years old
I'd sell them as they'll be quite noisy and you'll have to fork out for a controller anyway.
For the money you make from selling them(or a 'little' bit more) I'm sure you'll be able to pick up a couple of Samsung F1 640GB's or 1TB's which you can stick in a Raid 0 set. You'll have more space, they'll be a lot quieter and faster.
It very much depends on the model. Could you post up the details from the tag? It'll give us a chance to find their specs and see if they're worth using or selling. You can pick up decent pci-e controller cards for <£100 now, and any half way decent scsi drive will fly when raided in that number, and on the plus side you could always raid 5 them at practically no overhead cost which makes for fast/redundant fun!
I found with mine that you can simply build an enclosure out of an old case, pad it with neoprene, and you can have a silent drive box that's fast and reasonably quiet!
