Ok I fully understand your point and apologise if I came accross as aggressive to you, you weren't a target in my posts. There is a sound difference betwene the fields, granted, but a lot of people regardless end up going into a helpdesk environment regardless of the path their CS degree should take them down, two of my friends among them. Starting in helpdesk can end up taking you where you want to go regardless of it not being what you specifically stied in your degree for... and my point was that it often serves as a platform to launch many and varied IT/computing-related careers.![]()
The NHS and other "super dooper important" projects are the biggest shambolic examples of IT projects in this country.What I was thinking. Plus if somebody messed with a cable it could be disasterous. The NHS operate Mission Critical Systems and having a novice just "one spilled cup of tea" away from the servers...well go figure. on the other hand if they DID allow people there and they did cause a mistake, people would then jump all over them and complain etc.
- Pea0n
Its OK to go and see a lady's fairy pot or watch somebody having an operation but its not OK to see a printer being set up to a computer.
Pathetic.
repair/upgrade = £30 for up to two hours, and a flat £65 for the day after that, £150 for a home network install and £600 for an office network installation, and a straight £45 on top of the cost of a new pc from me if bought.![]()
It's amazing how nice you can be when they're giving you money isn't it?![]()
You've indicated what the biggest failure is, and it's not what you think it is. It's a lack of communication, and incorrect priorities.Sadly I have to agree, only been in the NHS for 6 months but the number of non-IT managers who have control over IT projects costing millions is absolutely shocking, the project plan changes constantly, they don't seem to realise that you can't keep shifting the goal posts without changing the hardware/software you're using - it's all mean to magically work. These people are in charge because they've historically run projects, but they've next to no IT knowledge at all,
So basically someone has made a decision that you don't agree with and have no power to change so you are sulking and throwing your toys out of the pram...
Get over it, if you don't like it quit whinning and talk with your feet.
I have the power.
Sounds like your worse than the techs
Coming from a shop floor enviorment i am suprised you did this, in my experiance there is not much worse than a 16/17k line manager who thinks hes god couse hes got a white jacket and a set of keys. If you don't respect the chain of command people like this will dislike you and sooner or later WILL **** you over.
