 - 29 Sep 2003
 - Newcastle upon Tyne
Does anyone know? I suspect 2 but it could be 3 like their old design. Thanks!
			it only get 80mb/sec read avg, the wd 640gb gets 95mb/sec, get that instead.
Two platters, they use the 250gb platters rather than the 320gb platters of the 320gb/640gb/1tb drives.
I believe all the F1's use the 334GB platters, just with only part of them enabled depending on the drive. THhs would make sense as prior to the F1's their disks used 166GB platters, there weren't any with 250GB ones.
no they use 2 250gb platters, and the 750gb uses 3. The F1 drives to buy are the 1tb, 640gb and 320gb as they all use the 320gb platters and are much faster than the other 2
OCUK dont sell the 320? only 640?no they use 2 250gb platters, and the 750gb uses 3. The F1 drives to buy are the 1tb, 640gb and 320gb as they all use the 320gb platters and are much faster than the other 2
I don't think that Samsung makes 250GB platters specifically for the 250GB, 500GB and 750GB models, I think they would use the same 334GB platters and just short stroke them, but I have looked to get confirmation on this in the past and could not find it.
all the drives are based around the 334GB platters even if the full amount isn't used.
The drive arrived today and it gets 80mbps sustained data throughput so it's almost certainly using 250gb platters. The 334gb platters get around 96mbps+
My 750GB as well, so it is very strange as it looks like the 750GB one isn't using 250GB plattersMy 750 does 95.1 average, same as the 1tb hard drives.
