Looks good, guessing you like family guy.
Icons were easy to make too weren't they?
More than helpful.
I don't think your wallpaper comes in 1680 though.So I've settled with something else off that site.
Wierd.
Here you go. Found the link.
http://junkandres.deviantart.com/art/RisingSun-thing-Widescreen-51431975
My Work Desktop
I just need to find some better AutoCAD (2009) and Map3D (2009) icons!.![]()
Can I get the wallpaper please mate? 1280 X1024 if poss?
piccie
This may be rather retarded but, how do you remove the Windows Taskbar completely?
I'm playing with RocketDock and am using it similar to a Mac, all stuff minimises to that, so I want to remove the taskbar to make it all clean.
InvG
Edit, never mind. Just try autohiding it.
It normally leaves you with a slight bar, and also then pops up when I don't want it.
Was wondering if there was a way to completely remove it.
InvG
