What CPU cooler is that?
Naud
My Hiper Osiris. Need to take some better pics some time![]()
You can run 120mm fans from the motherboard, the motherboard manual should state what the maximum current draw from each fan header. I think high power fans like the Delta's are a no.
Rob
Never knew that, I have a low-power 120MM fan and a DFI-Expert (Quality board), would that be ok do you think?
Also, you said fanS, is it safe to run more then 1?
My Abit IP35 Pro has 6 fan headers, plug one fan in each, if they are low power fans you might get away with plugging 2 in!
Your fans will be fine.
Rob
I have at least 2 or 3, I think (without opening up the case and checking), connected to my ASUS P5K Deluxe and it's fine.
