Hi Guys,
I have just flashed to 0612 from 0404 and i'm experiencing instability when i try and change my ram timings from 5,5,5,12 -> 4,4,4,12. Note: I've managed to restore all other settings, although i've left the DRAM CMD rate to auto.
Before i upgraded i literally wrote down all my settings but i've noticed that there are ALLOT more options within this new bios. Hopefully this is where you guys come in! Can anyone spot a setting/settings that might be A) causing instability or B) directly contributing towards the above problem.
Note, i have been running at 3.5 (440*8) using 1.4875 (CPU volts) for a few months @ 1 hour prime stable.
In order to make easier for you guys, I've taken some pics of my bios.
Top performance settings
[URL=http://imageshack.us]
[/URL]
Bottom performance settings
[/URL]
CPU Settings
[/URL]
Northbridge settings (default)
[/URL]
As always, any help would be greatly appreciated.
[/URL]Bottom performance settings
[/URL]CPU Settings
[/URL]Northbridge settings (default)
[/URL]As always, any help would be greatly appreciated.
Anyways, 10mins of prime and it appears table @ 3.5 as before. Loads temps of around 73.
