- 7 Mar 2005
- LU7
Any chance of a link? Email in trust.Ok, finally sorted out my Vista install, and here is the current desktop...
InvG
InvG
Thank you. 1680x1050 btw.![]()
You'll either have to stretch mine or use the naffy colour one.
What tweaking did you do in Photoshop and reckon I can mimic that in Paint.Net?
Does objectdock work in vista 64bit? cant seem to see on the websiteAh sweet, I thought you could only do this with objectdock pro but check this out.
(a few swear words in the vid, mods remove or i'll remove it people don't wont it on here.)
site to get stacked docklet from here
A[L]C;11763161 said:Does objectdock work in vista 64bit? cant seem to see on the website
Yeah, I had that problem too mate, re-installed iTunes and it was fine. Not sure why i didn't have a plug-ins folder in the first place lol
Yes it does. I've been using it for a long while with no problems.A[L]C;11763161 said:Does objectdock work in vista 64bit? cant seem to see on the website
http://wallpaperstock.net/coyote-natural-bridge-wallpapers_w4810.htmlcan i have a link to the one on the right please?
in 1680x1050 if possible
