Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
That's excellent at such low volts, looks like u found a good one, i am only at 3.2 @ 1.575v on my e2160. I suggest u try getting up to 3.6 upping the vcore (depending on your cooling of course).
The cooler i am using is only a cheapo Nexus all copper version of the Intel cooler but with a bigger fan. Still, temps at the moment are 58 degrees on both cores after 8.5 hours of Prime small fft's. His cooler is a Freezer 7 Pro though so should be better. The problem i have at the moment is the ram. My spare set is only Corsair XMS 5400 (675mhz). I might swap it for the Geil 6400 kit in my second pc tomorrow to see how far it will go. The best bit is that i have'nt had to touch any other settings in the bios apart from the dram frequency and Vcore. Everything else is at stock.
