1a)My Focus has the anti-hijack door locks. It's annoying.
You can turn that off.
Soft Closing doors on the M5 and M6.
Always tell my Mother and Father that there is no need to slam!
Josh
Cant on mine![]()
1. Turn on the ignition to position 2 but dont start the engine
2. Lock the door by pushing in the button below the handle, and then pull the handle slightly to reopen it (Repeat this operation three times)
3. Turn ignition to position 1
4. Lock the door by pushing in the button below the handle, and then pull the handle slightly to reopen it (Repeat this operation three times)
5. Turn on the ignition to position 2 but dont start the engine
A beep should be heard
6. Lock the door by pushing in the button below the handle and then pull the handle slightly to reopen again
A final beep should be heard.
too many to mention though.Focusowners and if your doors autolock as you pull off. You must have the GEM module?
b) When you want to indicate on the motorway for example on most cars inc mine you have to fully initiate the indicator stalk or hold it for a few seconds whilst you manoeuvre into the new lane. On the Seat I noticed if you simply tap the stalk it will indicate 3 times then go back to rest - perfect for switching lanes without having to hold it or take it off indicator like on other cars. I also thought this was a really neat feature.
push the door almost closed (very close), it then closes itself! just pulls the door in.
kinda hard to explain more than that.
Is that its official name? thats probably what im referring to
excellent feature.
I'm not entirely sure, that's what my parents call it...
I love it! Wonder how much it was be to get it on a Mk6 Fiesta!
Josh
EDIT - A quick google does say it's soft close.
http://www.bmw.com/com/en/insights/technology/technology_guide/articles/soft_close_automatic.html
[TW]Fox;11842558 said:This is the most annoying thing ever, the 530d does it and I had it turned off on my 530i. Becuase the E39 doesnt unlock the doors once you turn the engine off, so you've got to manually unlock them.
GRR.
Does pulling the interior handle not unlock the door? Granded's punto does, I still don't like it locking the doors past 10mph tho.
[TW]Fox;11843646 said:It does, yes, but then you've got to pull it again to open the door. It wont unlock and open in one handle-operation![]()
I've driven a new Astra and a new Transit and they both do this. I find it annoying as I can't give a single left-right-left flash to say thanks to the person behind.
excellent feature.
