Are these crops? They all seem quite soft and noisy.
Great set Joe. I take it this was with your Sigma 120-300 with a 1.4x teleconverter? Do you notice any performance loss with the teleconverter on compared to off?
Yes they are crops - you dont think its easy to get that close to a woodpecker do you???? Taken at ISO 400 with only some noise reduction.
Good shots.
Number 1 is the best in my opinion, except you've chopped the bottom of his tailfeathers off! also like 8.
Number 5 is ok, but I think it'd work a lot better from a lower angle, number 6 is a better shot but the colour/highlights are a bit out. maybe p/p?
Which reserve was it?
Cheers.
I might have a play with number 6.
They were taken at The Lodge (Sandy). Only one hide, but it was reasonably good.![]()
