The new ones don't have a ring anymore.
I've started on the road to get me the same spec, and I have hte same hard drive as you
Can anyone recommend a nice speaker setup to compliment the iMac? I have an old creative 5.1 system, but fancy more tidy 2/2.1 setup now.
Looking at the outputs I can only see a Microphone jack, which the Apple specs describe as 'Headphone/optical digital audio output (minijack)' Doesn't look like an optical output to me?![]()
mark66 said:Can anyone recommend a nice speaker setup to compliment the iMac? I have an old creative 5.1 system, but fancy more tidy 2/2.1 setup now.
Cheers, these ones had certainly caught my eye, they do look quite cool. The reviews are pretty much excellent too.http://store.apple.com/uk/product/T...c/mac_accessories/audio_speakers&mco=MzQ1MTM0
If you're going to spend so much on a mac, don't let it down with bad speakers. These sound amazing, despite the low wattage.![]()
My iMac came with a cleaning cloth, didn't yours? I think it was packed with the 'Everything Mac' leaflet. Black cloth in a clear plastic wallet, about CD size.Rather than starting my own thread...
Just got myself a 20" iMac mid-week and loving it obviously. So much different from my MacBook - more space! Buttttt: what does anyone recommend for cleaning the screen? The slightest things show up due to the glossiness! Currently using a really silky glasses cleaning cloth, but some liquid might work better for a more thorough clean every now and then?
Yeah, it's in there - I use this same cloth for my MacBook though, didn't bother unwrapping theirs. Sometimes have to work quite hard to remove things on the screen though, wondering if a liquid works better every now and then.
More I wipe my MB screen, the more dust it attracts too![]()
Excellent, did some reading up, formatted the MyBook to OSX Extended and it is quick enough for iMovie, so I can capture and edit all my home video directly to and from itThe Mybook has Firewire 800 so transfer rates have been pretty good so far. Have yet to see if iMovie can handle reading footage from it whilst editing, hopefully it can, otherwise I will have to copy back over the clips I am working on.
