- 8 Mar 2004
- London, UK
What I want to do:
I have a P35-based motherboard with an ICH9R south bridge. I would like to connect 8 SATA disks to the ICH9R so I can use Intel Matrix Storage to build an 8-disk RAID10 array. The ICH9R has 6 ports. I planned to use a port multiplier to put 3 SATA disks onto a single ICH9R port so the configuration would be:
Port0 <> Disk0
Port1 <> Disk1
Port2 <> Disk2
Port3 <> Disk3
Port4 <> Disk4
Port5 <> Port Multiplier <> Disks 5, 6 and 7
The problem
When I connect my port-multiplier + 3 SATA disks to an ICH9R port the system reports that it can only see a single SATA disk on that port. In other words, if I connect 8 disks to my ICH9R (5 disks connected directly and 3 disks connected via the port-multiplier) then the system behaves exactly as if only 6 disks were connected. The port multiplier and the extra 2 disks are completely invisible to the system.
Stuff I've done to try to figure out the problem
Reading the Intel documentation, it sounds as if it should be possible to connect 8 disks to an ICH9R. For example:
From the P35 overview:
From the Matrix Storage overview:
(The P35 counts as a "2007" chipset, surely?)
I've also tried connecting my port-multiplier to the "Gigabyte" SATAII controller on my motherboard and it works as expected (so this confirms that the port multiplier functions correctly). However, I'd much rather have all 8 disks on the ICH9R so I can use Matrix Storage to make a 8-disk RAID10 array.
So far, I've only tried connecting the port multiplier to the 5th and 6th ICH9R ports. I'm currently backing up my existing 4-disk RAID10 array so I can see if any of the other ICH9R ports can handle port multiplying. However, I'm not optimistic. After doing a bit of reading around on the Internet, it sounds like the ICH9R might not be able to handle port-multiplying, despite what the Intel documentation may say. Urg.
Any help would be really appreciated!
specs
Port0 <> Disk0
Port1 <> Disk1
Port2 <> Disk2
Port3 <> Disk3
Port4 <> Disk4
The problem
Support for external SATA (eSATA) enables the full SATA interface speed outside the chassis, up to 3 Gb/s.
In 2007 Intel Matrix Storage Technology has further extended its performance and protection capabilities outside of the PC. In 2006 eSATA* was introduced to Intel chipsets and natively supported with Intel Matirx Storage Technology, in 2007 support for port multipliers enhanced this capability by allowing multiple drives to be connected to a single eSATA connection. Now a user can utilize RAID capability on multiple drives outside of the PC, an ideal solution for small form factor PC's needing extra storage or for users that require increased storage capacity that needs to be protected.
specs
- Gigabyte GA-P35-DQ6 motherboard
- Win XP Pro 32bit SP2
- 4GB RAM
- Boot disk lives on the Gigabyte SATAII connector
- Lian Li V2100+ case with 850W Corsair PSU
- All the latest drivers and BIOS
- The BIOS is set to enable AHCI for the ICH9R SATA ports.
