- 13 May 2004
- Wales, Wrexham
I managed 22mpg in my RX-8 once.
Its does help air flow though.
How can the wastegate be fully open when its controlled by a pneumatic-mech actuator that is actuated by the intake manifold being pressurised to open it and limit boost.
Its closed, you get zero turbine bypass, shaft torque then churns a fair amount of air into the intake and reliveses some of the cylinder demands from the downstroke of the piston, hence reduced pumping losses = higher efficiency.
Hang on...are the people quoting impressive MPG using the fuel computer or measuring it properly by filling the tank? After getting an indicated 60mpg from a 130PS TDCi Mondeo whilst actually achieving around 40mpg I don't believe them any more.
only the LCR owners will appreciate how pretty frigging amazing this is
As An LCR owner I appreciate hot pretty anal this is![]()
Nice work!
Do you like the engine though?
As An LCR owner I appreciate how pretty anal
[TW]Fox;11912313 said:Always thought you LCR owners were a bit odd![]()
OMG My turbo is spooled up at motorway cruising speeds too. I want that medal.
oi
several of us "LCR" owners also own bmws
[TW]Fox;11915443 said:I don't think having a rusty G reg 3 Series in your garden thats not moved for 6 months really counts.
[TW]Fox;11938660 said:You are so slacking it took you 3 days to take that bait![]()
[TW]Fox;11907668 said:I got 19mpg average out of the Z4 today.
I want, no demand, some coolpoints for that tbh
