Catalyst 8.6 out
just did a 3dmark run and lost about 10pts on both sm2 and sm3 scores which is within the margin of error. So I can safely assume these do nothing for 3dmark06 :p
Regarding this new install system - how safe do you think it is? I'm used to booting to safe mode, wiping drivers clean with Driver Cleaner then rebooting to install new ones - which is quite an annoying process. Has anyone tested this "install without rebooting" process?
Yes & works just fine.
I won't be able to tell any different cause I've just upgraded my pc and it will be the first time I've played on it :) but I'll try them anyways :)
