- 16 Jan 2003
- Nottingham
It's the original Accelero S1 that I've got on mine, the holes for mounting are 75mm across the diagonal. It was sitting in the cupboard from when I had an X1950 card, and I used some old motherboard mosfet heatsinks for the mosfets on the GPU. I've also got a rev2 version on another card, and I think that just fits more cards as the mounts are adjustable?
So basically, rev1 or rev2 will both fit.
Idle in my system is around 45c, and goes up to about 65c under an hour of Crysis loops. The figures quoted above must have good case cooling, or they've got some kind of fan on it?
Looks like they have a fan on it.
