About 80C idle, and 95 under sustained load.
Wowzer.
You tried changing the thermal paste on them?
Getting any more for Tri and Quad?
Wowzer.
As for getting a couple more, I'm waiting now until the 4870's come out next week. I have two of those ordered for day of launch (25-6-08) and those I'm going to water-cool.
Sapphire X4850 512Mb on JW-X48D2-Extreme
Single card 3DMark 06!
Next - CrossfireX of course![]()
I'm looking at the Accellero S1 conversion at the moment - and if I do that I'll change the TIM.
Dont make me buy one to give WJA some company, he looks lonely in here all on his own.![]()
Does that make me a J&W Fanboi?
Seen as you seem to be the only person to have this board on OcUK, quite possibily in the UK (but unlikley) then yes it does, the biggest J&W fanboi there is.![]()
well the reason i didnt try this board was that i didnt want to be a guinea pig
especailly as the j&w p35 had some issues.
Hows the disk controller of this x48?
i thought id stick to asus, familiar with the bios (although its now got all this skewing nonsense amongst other unfamilar settings lol) etc..
have you tried an asus p45 board yet? they seem to be easily hitting 500mhz fsb
with the quad Q9's
lol go through this thread, http://www.xtremesystems.org/forums/showthread.php?t=189437
plenty of 7,8 & 9 multiplier quads easily doing 500 fsb
i can even do 495 with my yorky Q9250 at 6 & 7 on air all on default settings (not even messed around with voltages yet)
can this x48 even do 500 if you drop the multiplier, didnt come accross it in your review
i would have thought the x48 would have been using the newer ICH10 controller like the p45 range
be back later![]()
You sure you're not just here for a bit of thread-trash?
Yes, the motherboard will do well over 500FSB if the CPU is up to it. And none of the X48's use the ICH10R controller, but you knew that already, didn't you?
Now, if you actually have a sensible query on this motherboard, then ask away. Otherwise, why not go off and buy, use and enjoy something else?
I have an ES Yorkfield with a 7x multiplier that is known to run in excess of 500FSB, so that's next I think.
any other J&W JW-X48D2-Extreme users out there who could give valuable feedback![]()
all my questions and statements are valid
now back to the disk controller, does anyone else know if its any good
there were reported issues with the p3 series
http://forums.overclockers.co.uk/showpost.php?p=10807505&postcount=12
which may have plagued this board too
also any results of this board giving >500fsb with the Q6/Q9's
edit: while you're here
did you not get to try your ES chip, should be good to see results from as it is "known to run in excess of 500FSB"![]()
