its 2008 now mate *hands him a calendar* 4gb ddr2 has been cheaper than 4gb ddr1 for a LONG time.
so "haha"!
O-Rly
so "haha"!
SuperCache is much faster than iRAM and you can dynamically reallocate the memory as you need to and there is no hardware to install.
http://www.superspeed.com/desktop/supercache.php
On a crappy Pentium D with 2.5Gb RAM I can write benchmark 1050Mb/s with supercache
You have a touching faith in UPSs. I've seen a faulty UPS take out a server and bring down the library system for half a county.The PC will/should have a UPS
which means you will only have data corruption in the event of application crash, driver error or BSOD
and this problem applies equally to hard disk, iRAM or SuperCache
Pagefile and Photoshop (or whatever) temp file would work well.Why not set up the I-Ram as the windows swapfile. It doesnt matter how much ram you have, many applications will still request swap space and use it. By having 4gb of ram on an I-ram and allow the entire drive to be used as swap you can get a pretty good performance boost. Especially if your running a 32bit os. With a 64bit OS of course you can just slap in more ram.
