Nice find, rates the CBR F4i at 3.52 (0-60), i can hardly hold on to mine sometimes, its kind of put me off getting a 1000cc motorbike in the future, i just cant imagine the power they would produce.
About right....0-100 mph in 4.6 seconds on a GSX-R 1000?
Is that right?![]()
Could well beLooks like data from a program called 'cartest'
Not with your fat arse sitting on it it isnt.0-100 mph in 4.6 seconds on a GSX-R 1000?
Is that right?![]()
I thought be Cbr 600 F5 was 105 Hp, but this data sheet is claiming its 90. If it is 90 it can certainly rip your arms off. Im kinda wishing i had chose something like an Sv650 instead of the CBR. The Honda is a great bike, but anything past 6k revs and it just turns into a rocket.
I think I came 'closer' to lifting the front wheel on the SV650 a couple days ago, although admittedly it was probably just loading the rear more than i've done before, as I was in 2nd and opened her up properly. I've not done a really aggressive start on it yet, not had to hold on for life anyway! In fact I need to try it, I did it on the school GS500 a couple of times. Dunno if it'll even lift a wheel as it aint a bullet, also i'm not sure if i'll die. Not like "humans will never go above 60mph" die, but what happens if you come down and you've turned the handlebars slightly? Is that even going to happen or am I thinking too much?
then your going to wish you went to the gym or had a steering damper hehe
