Sigma 150mm F/2.8 EX DG macro.
14 Aug 2006
Land of Dragons
Question for the guys using this lens, anyone using/used the 1.4X with it ?.
I know the AF will still work ok, but looking for info on the IQ with the 1.4x, before parting with cash for the Tele-Converter.
Really just trying to extend the focal length to a 210mm, if I can keep the excellent IQ the lens has already.:)
cheers.
can this lens work as a decent prime lens - i know it will focus to inifinity jsut wondering how well it works outside of the macro range?
33L a lot of the members on flickr use it as a portrait lens check out the groups for the lens
should be getting mine along with the sigma 10-20mm in a couple of month :D
cool - just what i wanted to know.
I will be using it for portraits as well. If the 1.4 TC works well then should cover a lot areas i need to.
thanks
Here you go My pics using it as a 150mm Prime :eek:
These are as they came off my 40D no Cropping or editing, only pilot shot,+shooting into the sun :(, I really rate this lens.
Cropped shot from above pic , of pilot being photogenic :)
Here is another one I took this morning , again with the Sigma 150mm macro.
Only started down off the mountain (Cader Idris )at 6PM tonight, OMG!!!!!!!!!!!!!!!!! Ill be climbing it again tomorrow :confused:
[/img]
