here's the blackfire stuff in action on a black car, you can see what I mean by flake pop here
http://www.polishedbliss.co.uk/acatalog/june.html
i just went to halfrauds....they may be a tiny bit more expensive but you dont have to pay for delivery.
arent the Dr Colorchip stuff suppose to be good for touching up paintwork? There was a huge thread on this forum with a group buy proposed about the product
would it be possible to have any advice on how to clean underneath the bonnet?
Thanks
T1rez!
so hand polishing will still impress you a lot!
meguiars super degreaser
P21S total auto wash
aerospace 303 protectant
raceglaze metal polish
blackfire wet diamond metal show polish
meguiars nxt metal polysh
the only cheap polishing machine i'd 'semi' recommend is the silverline...I say semi as it's a rotary rather than a dual action so, if you've never used one before, it's a lot easier to burn your paint with these bad boys and a lot easier to mess it up. So if you plan on getting one read and watch tutorials first and ideally get a practice panel to learn a bit on first
it's also not that cheap really once you've factored in good backing plates/good pads/polishes/inspection light/masking tape/probably more stuff![]()
they're not deep gouges or owt like that - i only notice them when i look fairly closely. they dont come out much on photos
