- 24 Dec 2006
- GB
How does my CPU compare to latest offerings?
Really?! I dont feel i would be able to swop the mobo tho! (Not very tech-savvy!)
well you have pretty much the best s939 CPU already? What else could you do ???
Are you looking at the newer AMD x2 "socket AM2" CPUs? the 5600+, 6000+ etc? For that you would need a new motherboard and new memory also
CPU limited!
Okay this phrase bothers me.
Just because you don't have a Core 2 processor it doesn't mean your computer is going to refuse to work. It just means that instead of getting 200fps, you'll get 190fps instead.
Yeah I know, what a tragic loss!![]()
To be perfectly honest, if you are prepared to get into overclocking those older S939 chips, which to the best of my knowledge do not support the 'AMD Overdrive' software based overclocking, then I'd say you're getting into something which is in my opinion, probably more 'involved' and potentially risky than actually doing a total motherboard, cpu and memory upgrade.
By saying this, I am by no means saying it is particularly difficult or risky at all. Far from it infact, I am just trying assure you that upgrading such components actually sounds more difficult than it really is. Once you've taken a deep breath and gotten your hands dirty once, you'll see what I mean I'm sure, this forum is a great source of info and support and you'll find no end of help and support if you're really worried about doing it. Go on, give it a go...you know you want to
Do you get everything you need to make a new mobo stable (and all aspects of it work) in the box? Do they come with detailed setup (software aswell) instructions?
Dont get me wrong....i've changed gfx cards, hdd's, optical drives, memory, and cpu's but never done a mobo. The bios set up and drivers etc make me a tad anxious!...i dont want to end up with a buggy unstable system!
