Assuming 4870 aren't cherry picked, how much quicker will an overclcoked 4870 be over a 4850?
I know the 4870 has gddr5 memory and can overclock to at least 4400Mhz but how much difference does the gddr5 memory make?
The 4870 has a much higher core speed than a 4850 but the 4850 could in theory run at the same overclocked core speed as the 4870.
What I am getting at, if the 4850 and 4870 overclock to the same core speed, does the gddr5 add 5% or 10% or what difference?
If only 5-10% then if you intend to overclock your 4850 especially under water, it is never going to be worth the extra £60+ to buy the 4870?
Comments, suggestions, actually overclocking results welcome.
