,94v 160mhz worked for me before my pencil mod. now with the pencil mod this translates to 1.15v![]()
Seen those figures around....Yours ? or someone elses, Much below .9 falls over !
Why 160mhz though ?
yeah the msi bios is what I used as a base. Anything below .94 doesnt seem to work.
Wouldn't want you to burn the card out early in it's life. Just some peeps tend to get a water setup, and then forget (or ignore) the importance of still having good airflow, thinking water is the cure for all.Depending what You did to the bios it's best to clean out and reinstall drivers..just swapping bios back will make matters worse, Also optimise 1 card don't try messing with multiple cards and bioses![]()
Ok I've drawn a conclusion regarding the 4850 is RBE does not seem to work correctly when You start modding power play levels/voltages, gurusans results are excellent but My sapphire cards will not run anywhere near his speeds (un voltmodded speeds)
The MSI bios with lower 2d settings work and reduce desktop power draw about 7 watts..pretty good when it is only 103 watts to begin with, but You can not get any overclock without problems.
At this moment in time I think RBE is not working correctly with the new cards and would advise anyone to Just use it for fan control and don't double edit bios files, start always with an unedited copy
be very interested if Anyone other than gurusan has had better luck than Me ?
Some crossfire on P35 benchies i've done:
Do game splay smoothly on the P35 crossfire with the 4850's. Just that when I tried in past, it ran quite horribly. Especially COD 4. Though I think most of the problems were down to powerplay bug, COD 4 simply did not like crossfire on the P35.
