WoW info from the WWI this weekend
28 Feb 2004
PvP
Lake Wintergrasp
* PvE elements are being added to this PvP Zone, for example the equivalent of Elemental Plateau in Outland is in Lake Wintergrasp.
* Siege Combat will be in both Lake Wintergrasp and the new Battleground (see below)
* Siege vehicles incude air combat with flying vehicles.
* You can destroy the buildings within Lake Wintergrasp and in the Battleground.
* Lake Wintergrasp will feature an attack/defend game type. Just like the Auchindoun Spirit Towers, when your faction holds a tower it will keep it for a certain amount of time and retain all the advantage for a few hours.
* Northrend "Spirit Shards" will be used to reward players. When your faction controls Lake Wintergrasp all the bosses in Northrend will start dropping them. You can then use these shards to buy rewards from a merchant, they won't be more powerful any other reward but just an alternative to other sources of equipement (like gearing up for PvP very quickly).
* "Wintergrasp Marks of Honor" will drop as well and will be redeemable for items through the honor system and other NPCs.
* Bridges will be used as "choke point" in the map, siege vehicles can't travel through water.
* The goal of Lake Wintergrasp is to capture the "Wintergrasp Keep", everything in that keep is destructable and you will have to break into the keep to capture the point.
* Players will be able to control stationnary cannons on each tower to defend the keep.
* Bridges are very large and very tall, players should be able to see them from anywhere in the map. They're also totally destructable as well.
Siege Vehicles
The Demolisher
* The Demolisher has both short and long range attacks
* It is meant to bombard players and buildings from a long distance, it's also equipped with a ram to siege buildings.
* It can hold up to 3 passengers, passengers are exposed and can be targeted individually. However, players can cast while the vehicle is moving if they're in it.
Forsaken Catapult
* The catapult is faster than the demolisher but its range is slightly lower.
* It does slightly less damage.
* It cannot hold any pessenger.
The Siege Engine
* This is the siege weapon with the longest range.
* The gunner is sitting in the turrent and has full control of the turret.
* The driver is only moving the vehicle.
* The passengers in this vehicle are fully protected but can't shoot other enemies.
* It's also got a very powerful ramming attack
Flying machine
* Flying Machines can bomb enemies, they're swift but very vulnerable to anti-air attacks.
Goblin Shredder
* The shredder is an anti-air vehicle.
* It will use anti-air rockets, they're long range homing missiles.
* This is a personal armor suit, if the vehicle is destroyed the player just jumps out and keep fighting on his own.
* You can use your sawblade as close range melee attacks.
* The shredder can jump into the air just like rocket boots for players. This can also be used to jump over walls.
* The shredder is very vulnerable to siege damage.
Northrend Battleground
* This battleground is located on an island south of Dragonblight
* This is also an attack/defend game type battleground.
* One team will attack and the other one defend, you will have a specific amount of time to succeed. After the end of the round teams will switch sides.
* Attackers will come from boats and defenders will start in the middle of the beach.
* There are 3 sections of walls in the Area, after each wall there are capture points and graveyards to make the attack on the next points faster.
* Attackers will get more siege vehicles depending on their progression throughout the siege.
* The battleground will be either 10vs10 or 15vs15, this isn't decided yet.
Arenas
* The point is to keep arenas simple, while leaving room to innovate.
* Stream lost at this point, will update later.
Dalaran Arena
* The arena is fairly small and mounts won't be allowed here.
* Arenas will introduce new "movable" objects, changing the line of sight of the battlefield every few seconds in the arena. For instance pillars might go up and down randomly, on a timer, etc ...
* There is a pipe coming from the ceilling, every once in a while a column of water will start dropping from this pipe.
* Each team will start in a pipe on one side of the map, as the match begins a column of water will "push" the teams out of their pipes to prevent camping.
Orgrimmar Arena
* There might have objects dealing damage to players, pillars moving up and down based on a timer. There will be visual signs on the battleground to warn players before something happens.
* Triggered objects will deal damage to players, for example when the pillars go down spikes will come up.
* Teams will be very close to each other at the beginning of the match. Players will start in elevators rising from the ground and will start 10 yards away from the enemy team.
* Mounts will be allowed in this arena.
* If you stay on a pillar when it rises up you go up with it.
* There will be spikes around the elevators, they will go down a few seconds after you reached the fighting area to let you the time to check what classes you're facing.
Q&A
* The battleground reporting system is being tuned to let player police themselves easier.
* A spectator mode is planned, but devs keep in mind that some players won't want to have other players spectacting them.
* Everything is done to make outdoor PvP more pleasant and prevent server crashes. All objectives in Wintergrasp are all spaced appart to prevent players from gathering at the same point, that's also why there are a lot of rivers in the zone.
* There isn't any plan to add racial abilities to each race.
* PvP rewards won't be changed, you will still be able to get some of the best item for some slots from the honor system, and the 5-part set from the Arenas.
* Battlegrounds starting without even teams is definitely a problem. Some changes will be made to the queue system to prevent the overlapping between the queues of each battleground and make sure that matches start with the same amount of players on each side.
Raid & Dungeon
Raids & Dungeons
* There will be 8 Level Up dungeons and 4 Max Level Dungeons.
* There will be a 10/25 players mode for each raid dungeon.
* Heroic dungeons will be made slightly easier, at least devs are going to make sure you don't necessarily need a specific class like a prot warrior to complete it.
* Some dungeons were too long in Burning Crusade and completing a dungeon shouldn't take more than an hour.
* Quests didn't feel as connected as they should and dungeons quest should implicate a bit more in the background of the instance. Killing bosses might even have an impact on the world.
* Gun'drak will be a level 80 Dungeon and the last objective of a huge questline going through the whole zone (Zul'Drak).
* Black Temple and Hyjal Summit were released too early, on a second thought it would probably have been better to release Zul'aman first instead of postponing it for more than a year. Developpers are going to make sure that Arthas is and feels like the final boss of Wrath of the Lich King.
* Attunements to enter Heroic instances will be removed.
Reputation
* You will be able to earn reputation toward a specific faction by becoming its "champion", for example by wearing a Cenarion Circle tabard while running Hellfire Ramparts you will earn reputation for both Honor Hold/Thrallmar and Cenarion Circle. Obviously tabards reputation requirements will be changed to something like friendly/honored.
Itemization
* More PvP gear will be delivered through the PvE system, it won't be the best gear but it will give you a chance to get started.
* More PvP gear will be added as reputation rewards.
* More items will drop from 25-man dungeons.
* Items will be changed by removing "unecessary" stats to make them usable by more classes at the same time.
* More recipes and plans will be added to the game, with a better representation between professions. Even if some recipes will still drop from a specific boss in a dungeon like in BC, devs will try to make some of them easier to obtain.
Death Knights
* Death Knights will be able to tank 5-man, heroics, raids dungeons, but in a "different" way. It will also fill a few more roles and won't be here just to tank.
The Oculus (LVL 80 Dungeon - Borean Tundra)
* The dungeon will allow players to use flying mounts, parts of the dungeon will allow you to get a drake and combat while mounted by using different abilities of each drake. Some drakes will be able to tank, some will heal, others will DPS.
Halls of Stone (LVL 77-79 - Storm Peaks)
* Halls of Stone will be located in Ulduar in Storm Peaks.
* All the dungeons in Ulduar were built by Titans and will really feel huge, however devs didn't want players to need a mount or anything like that to go through it and tried to keep it small.
* The storyline of Uldaman will continue in Ulduar.
Caverns of Time: Stratholme (LVL 80 - Tanaris)
* The faction requirement on the Caverns of Time teleport will be removed.
* The dungeon is fully scripted just like Old Hillsbrad. There are a couple of timed encounters, it will be non-linear and you will be able to choose your encounters.
* Players will be fighting alongside Prince Arthas before he falls to the Lich King.
* The same voice acting as Warcraft 3 will be used in the instance. (Jaina / Arthas / Uthar)
* The Infinite Dragonflight storyline will continue here.
Q&A
* Whenever it's possible, devs would prefer to deliver legendary items through quests like Atiesh instead of having them just drop from Bosses.
* There won't be any attunement for heroic or entry level raid instances. The remaining attunements will be very simple to understand.
* "Wipe management" is a very important part of the design and developpers are doing their best to make sure that corpse run in dungeons aren't too long.
* Titles might be added for kills, entering a specific area, etc ...
* More tokens will drop to minimize the impact of randomization, sometimes increasing the amount of items dropping from a boss isn't enough.
* Dungeons aren't going to be overall easier, but will be more accessible. Bosses might not be easier to kill but will be easier to understand for new players.
Classes
Death Knight
* People playing a Death Knights will see the original voice of their race slightly modified to make it sound more ... Death Knight-ish.
* Tanks will be interchangeable in 5-man dungeons but tanks will have a speciality in 25-man raids. Death Knights will be best against casters and shouldn't be too far behind on other encounters.
Druid
* Entangling roots will be useable indoor.
* Nourish will be a new healing spell, healing for more hit points for each HoT effect on the target.
* There isn't any plan to change cyclone
* There will be a new model for the Druid's Dire Bear form and the Dire Cat form will be introduced.
Hunter
* All kind of pets will have their own talent tree. A tanking talent tree, a DPS talent tree, and an utility talent tree. Each kind of pet family will have its own talent tree and its own unique ability.
* The shot clipping will be removed from Steady Shot, you'll be able to use it without "interrupting" your autoshot. Hunters will be able to just smash their button.
* There are going to be new pets in WotLK.
* The skill points for each pets are being changed to the new "Pet talents" and will disappear.
Priest
* Divine Hymn will be a deep-holy talent protecting your party from attackers, any attacks done to you or your party will cause the attacker to be afflicted by sleep.
* The 51 point talent for Shadow Priests is Dispersion : You disperse into pure shadow energy, reducing all damage taken by -90%. You are unable to attack or cast spells, but you regenerate 6% health and mana every 1 sec for 6 seconds.
* Guardian Spirit - Calls upon a guardian spirit to heal and watch over the friendly target. The spirit heals the target for 642 every 2 sec, and also prevents the target from dying by sacrificing itself. Lasts 10 seconds.
Mage
* Mages are getting a Frostfire bolt dealing Frost-Fire damage to make elementalists more viable.
Shaman
* Totems are being "condensed" into a smaller amount of totems, for exemple Strength of Earth and Grace of Air totems will be merged into the same totem
* A new weapon enchantment will be available "Earthliving Weapon". It will increase the healing power of the Shaman.
* Flametongue will give spell damage bonus to the Shaman.
* Totems are being moved to physical school, you can't counterspell anymore.
* Totems will also affect raid members, not just the local party.
* Shamans are getting "Hex", a polymorph-like spell on a medium cooldown allowing them to turn an enemy into a frog. The enemy cannot cast or attack but is still in control of his character.
* Windfury won't be a weapon enchant anymore and will be changed to a buff. You will be able to use it in bear form or with poison.
Rogue
* Rogues will get a talent called "Fan of Knives", an AoE ability allowing them to attack all enemies within a short range. It will be some kind of "emergency" ability and you won't be able to spam it.
* Sap will now work on more targets, humanoids, beasts, dragonkins, demons. "Anything with a skull and a brain inside of it".
* Dagger specialization will be improved for rogues in Wrath of the Lich King.
Paladin
* Retribution paladins itemization will be moved to the same item as Warriors/Death Knights
* A new reactive healing spell will be added - Hand of Purity.
* Paladin's short-term-blessings no longer overwrite long-term-blessings.
Warlock
* Demonic Circle will allow warlocks to scribe a circle in the ground to teleport to it later with another spell.
* The 51-Point demonogy talent is a Demon-Form, this will allow you cast AOE Shadowbolts
Warrior
* Titan's Grip is a new Fury talent and allows warriors to wear 2 hand weapons with a single hand.
* Protection Warriors are getting a spell called "Shockwave" allowing them to damage and stun all the monsters in front of them.
* Bladestorm will be a new Arms talent whirlwinding all enemies in range every x seconds for a few seconds.
Some info is taken from presentations other is taken from the Q&A session
http://www.mmo-champion.com/
Any word of when it's due out? I'm starting to get a feeling they're struggling to get it done by the end of this year.
Edit:
How much more are they going to dumb it down?
No date was given, i really hope they dont drag it out like TBC the game in the months leading up to TBC really died as guilds stopped raiding and people couldn't be bothered to play until it came out.
Not so much dumbed down just less time consuming which I say is a good thing.
They will make a shedload more money appealling to casual players who can squeeze in 60mins play here and there, than if they built it around hardcore geeks who are never off the servers. :p
It certainly would make me happy. Anything which makes doing an instance less time-consuming is welcomed by me.
A lot of the hardcore gamers are gonna get miffed that people are getting good gear easier.
I mean, its good to cater for casuals, but it annoys some geeks hehe
You can already get good gear very easily, Gladiator Gear anyone?
However I've gone against a ridiculous amount of retards in PvP lately who just cannot play their class, despite having 'good' gear.
No word on Inscription (new profession) yet then? Just wondering how it's gonna work, what benefits it will offer etc.
Anyone know anything about it?
Shaman
Some awesome changes there, strength or earth and grace of air in one totem :eek: sweet
Plus polymorph and windfury buff :D druids and hunters will love that last one.
Good to see they're changing flametongue, windfury is too dominant, by adding spell damage it just might change the class dymanic quite considerably.
I'm in two minds about this tbh, it means that people in none hardcore games can get them, but I do hope the quest chain(while not being based around a stupid amount of grinding and also not dependant a large amount of group quests) will take a huge amount of time and effort.
Thats going to rock, hard! :p
Agree, for too long Shaman have merely been an afterthought for Blizzard. It finally sounds like they're actually thinking about the role of the shaman - root and branch.
I like how they are giving shaman a bit of CC, its definitely been something they have been missing.
Damn I remember vanilla wow release - Shaman were by far the strongest class in pvp, everyone complained about them.
It's not going to make them any easier such that they drop off trash mobs in 10 man raids. Atiesh involved getting lots of drops off Naxx bosses, followed by having to kill a hard boss in AQ40 as well as following a quest line. Compare this to the Warglaives which drop randomly off Illidan - some guilds killed Illidan for months and months before getting their first Warglaive, while others got one on their first kill. The changes will almost certainly be to limit the effect of the random number generator, while not removing the challenge of obtaining them.
Titan Grip seems like a total gimmick to me. :/
Thank God for shorter instances too. I'm a hardcore player but I hate how long it takes to clear Shadow Labs for instance, or at least how long it took when I first hit 70. There's just no need to spend that long clearing trash mobs.
It all sounds good to me.
Easier rep = less rep grinding
No or less attunement = less pointless obstacles
Shorter instances = less worry about spending all night in one instance
Since I stopped raiding about 2 years ago all the stuff in TBC has made wow still worth playing. The stuff here will make it even easier to play casually or "for fun" as i like to say.
