Q6600 users what's your vid
1.275 on my B3 currently residing at stock due to it being like a proper heater in my case with 2 hd2900's in there :(
Heres mine I got the other day :D
sem said
but i lapped it and my TRUE and dropped the temps by 10c
Wow thats some drop in temp from lapping 10c kin hell :eek:
Never heard of a 10c temp drop b4 from lapping 1 or 2 yeah,can i post you mine to do lol
that was only 10c at load and it all depends how bad your IHS and heatsink are
I got 1.208 in cpu-z and 1.250 in core temp(which isnt accurate as it said i was still on 1.25 when i was on 4ghz ^^), think i will believe the cpu-z :p tis on stock settings atm but will run 3.995 on 1.52v in windows i think it was
One I'm playing with atm;)
There is loads of info on the VID's of current Q6600 cpu's in the Quad database (see my sig).
My first chip was a 1.3250vid that didn't clock well. Ended up settling for 400x8 but needed silly volts for anything better.
Got a new one in the post this morning :)
Just playing with it now. It's another 1.3250 :mad: but seems to be doing much better. Currently priming at 3200 356x9 and have just had to make my first vcore increase due to a BSOD. Hopefully this one will do a bit better.
leave this forum NOW
my Q6600 has a vid of 1.2375 had to go through 5 before i found this gem :D
does 3.6 @ 1.36-1.4 (still testing) and 4.05 @ 1.5-1.55
temps where a problem at first in this hot weather but i lapped it and my TRUE and dropped the temps by 10c
after 15+ hours of prime max temp was 69c and that was on the hottest day in the UK so far
Recieved my first quad just the other week and it has the same VID 1.235. Guess I got lucky:D
It's only clocked to 3Ghz at present. Idles around 39-45C, 100% load gives me 56-62C. That's using a TT120 inside a sonata III, all 3 fans set fairly low. Fans cranked all the way up only gives a 3C drop. I'm worried these temps are a little high, or am I just paranoid?
IF you havent lapped it then that might be your problem as the TT's are very uneven surfaces from my experience
I aint sure if mine was properly or not, was at 4 with 1.25 :S
Thats speed step doing its thing - not started clocking yet. I have my suspicions that this board aint reading the VID right tho as I aint ever seen a VID that low.
SpeedStep does affect the VID reading.
Mine -
