1.168v while doing some encoding.
Ok, no more showing off now.
Wow thats some drop in temp from lapping 10c kin hellbut i lapped it and my TRUE and dropped the temps by 10c
Never heard of a 10c temp drop b4 from lapping 1 or 2 yeah,can i post you mine to do lol
tis on stock settings atm but will run 3.995 on 1.52v in windows i think it was
but seems to be doing much better. Currently priming at 3200 356x9 and have just had to make my first vcore increase due to a BSOD. Hopefully this one will do a bit better.leave this forum NOW
my Q6600 has a vid of 1.2375 had to go through 5 before i found this gem
does 3.6 @ 1.36-1.4 (still testing) and 4.05 @ 1.5-1.55
temps where a problem at first in this hot weather but i lapped it and my TRUE and dropped the temps by 10c
after 15+ hours of prime max temp was 69c and that was on the hottest day in the UK so far
how come it is only on 1.86 O,o
IF you havent lapped it then that might be your problem as the TT's are very uneven surfaces from my experience
Thats speed step doing its thing - not started clocking yet. I have my suspicions that this board aint reading the VID right tho as I aint ever seen a VID that low.
SpeedStep does affect the VID reading.
Mine -
