Open CCC and enable ATI Overdrive.
Click the Profile tab/Profile manager and create a profile (name it standard).
It will create a file called standard.xml in (users/name/appdata/local/ATI/ACE)
Now create another profile called Fanspeed. This will create another file called Fanspeed.xml in (users/name/appdata/local/ATI/ACE)
Open the Fanspeed.xml file in Notepad. The bit were interested in is as follows.
<Feature name="FanSpeedProtocol_0">
<Property name="FanSpeedProtocolProperty" value="Percent" />
</Feature>
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Automatic" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
Change this line <Property name="FanSpeedAlgorithm" value="Automatic" />
to be
<Property name="FanSpeedAlgorithm" value="Manual" />
Now change this line to you desired value (something between 30 and 50) 35 works well for me on an overclocked Sapphire HD 4870.
and replace the zero here
to something between 30 and 50
I think the changes are in increments of 5, find one that has a good balance of cooling at heavy load and is still quiet. (example 35).
Now save your file and select the changed file in CCC/Profiles and activate it.
