virtual hard drive
18 Sep 2007
i have just been given a piece of software for free called 'farstone virtual hard drive pro'
you can use it to create a hdd using a proportion of your ram to supposidly speed things up. anyone had any experience with this? would it make things faster?
How can you run files from you ram? Sounds interesting not something I’ve looked into before.
basically loads part of your HDD into RAM and therefore anything on the virtual HDD runs quickly as its not having to do read/write to the HDD... try loading superPi up in a RAM drive and look at the time difference :) can get a good 1/2 - 1 second faster on a RAM drive @ 4.2ghz compaired to of the HDD
could something like the page file or some other windows component be put there, although would the ram disc need to be mounted after windows loads.
could an application be installed on there such as a divx encoder, or the temp folder for dvd writing (you would need 8gb)
i might have to buy more ram
To mount Windows components in a ramdisk you need a physical ramdisk device, usually an expansion card that takes DIMMS.
You can use them for whatever you like but I'm not sure why you'd want one for writing DVD's, they only write at about 20MB/s tops.
Indeed. There's the Gigabyte I-Ram, but it's fairly hard to get hold of, and only takes DDR1.
I use a RAM drive for my internet browsers, makes browsing a fair bit quicker, also faster loads times.
Mind me asking what ram-drive software you use?
All hard drive speeds do for games is reduce loading times. Given that the slowest loading games are the most recent ones which would require lots of RAM there's no point.
I use a RAM disk for the cache folders for some applications (browser/usenet downloading) to reduce or delay reads and writes to the disk.
Nope, (very basically) the whole purpose of the page file is to be used as virtual memory when you run out of the real stuff...the operating system "pages" in-memory stuff out to disk (normally stuff that hasn't got current focus/execution context). Putting your pagefile in RAM would defeat the purpose of it.
no point, no current home computer can encode DivX or MPEG-2 faster than they can write to disk.
Save your money, very few things are sped up using ram disks - databases being the only one that springs to mind.
Yep PhilJohn's right, not a lot will get a massive speed gain from using a portion of RAM as a virtual harddisk, the limited memory means it's of no real use for loading games off of, and as he points out DVD encoding etc is limited by the speed of the diskdrive these days.
I really can't think of much that'd see much benefit from the faster read/write times on offer. Possibly it could be useful for converting file format's if you could load something on it? Though surely that's CPU limited... I'm not sure and I'm tired so ignore me!
Using a ramdisk will in most cases and usage scenarios slow down your computer as you'll actually have less physical RAM available and hence the OS will page stuff faster, leading to massive slow-downs (paging stuff to disk is expensive).
RAM disk aren't really for general use and putting a few things on so programs load a little faster. With games and program files you get a lot of hard drive reading for maybe 30 seconds every so often and you're using the game/program so the affect it has on the rest of the system doesn't matter.
They're better used when there's a lot of I/O going on that is hurting overall performance. In my case my usenet clients use a ram disk for cache, the parts of articles are downloaded to a ram and then the complete files are written out to disk. Without that I'd have constant writes of 2-3MB/s, doesn't sound like much but it slows things down. On a server you might load a whole database into a ram disk.
A ramdisk program was actually included with MS/DOS. I used it on my first PC (an Apricot) which only had twin floppy drives and no HDD but don't think I did once I'd got one with an HDD. A full MS/DOS boot floppy creates a ramdisk so it has room for all its utilities.
