so in conclusion - people who believe in conspiracy theories are complete retards.
i think thats about covered it.
So you think that Governments are completely honest and trustworthy, would never put a foot in the wrong place, and only have your best interests at heart? Obviously, people with that much power would never use it to their own advantage. Hell no. People are all nice, right?
Fair enough, I'm not arguing that. But what about the 90 floors below which aren't damaged or on fire? That still retain their strength and integrity, are designed for stresses way over what they're likely to encounter, and are highly likely to slow the progress of any collapse from above?
When one of the towers started to collapse, it started to collapse naturally. The top went for the path of least resistance and tilted over to one side. Then all of a sudden, every floor went down in a domino effect at almost freefall speed, which is so unlikely to happen its laughable, and the tilted top went down with it.
The US actually planned to launch missiles at one of there own ships of the cost of cuba so they could go to war.
Well the top steel supports were seriously weakened by the fire, probably around 25% of their original strength, and with the impact also taking away structual integrity; one floor eventually broke away and fell downward, onto another weakened floor...which itself collapsed... see what's happening here? It IS a domino effect.
FFS read that bloody pdf..But its not like a string of dominos, it would be more like:
Fall...Hit...Break
Fall...Hit....Break
Fall...Hit......Break
Fall...Hit...........Break
You see what I'm saying? The floors would fall and hit the floor beneath. The floor would take the impact then crack and the fall would continue. The combined floors would hit the next floor which would take the impact and slow it a touch more, then that would give way to the next floor and so on and so forth.
Imagine it as a bullet fired through multiple sheets of metal. The bullet slows down with each impact until it can't progress any further.
Instead, all three buildings fell at almost free fall speed - as in, there was very little slowing down the rate of descent.
why is it laughable?
its quite sensible, top floor collapses onto second adding more weight than the columns were designed to hold at those particular points, this added with the extra force due to the velocity of the fall causes the next floor to fail which carries onto the next floor, so now we have the weight of 2 floors falling onto the next ,and so on... not to mention the loss in strength of columns because the floor above is already missing
Assumptions, nothing more.But its not like a string of dominos, it would be more like:
Fall...Hit...Break
Fall...Hit....Break
But the columns are already designed to hold up the entire weight of whats above it, plus a hell of a lot more because its designed to take plane impacts, earthquakes and hurricanes. So I can't imagine how a few floors crashing downwards is going to have such a destructive effect. Remember, no Skyscraper - ever - has had this happen, even when they've been burning for well over 24 hours.
Fall...Hit...Break
Fall...Hit....Break
Fall...Hit...Break
Fall...Hit....Break
nonsense
.. from some random website I just googled."Collapse of any modern steel structure is highly unusual, and collapses caused primarily by fire simply do not occur. The design of the WTC towers was intended to be survivable even in the event of an airliner impact."
