2nd xbox 360! (Modification)
Cut a big hole in one side and stick a 120mm silent fan on the side extracting hot air. Then replace the two rear fans with some silent ones too. I would imagine this would significantly aid cooling with the easiest possible mod.
I could be very wrong though - it has been known!
Very bad idea, the side fan should be blowing inwards.
ive had mine since release, got the rrod error jsut before ms announced the extended warranty and after my original warranty had ran out so i ripped it open, stuck some arctic silver 5 on the cores and it's been running fine ever since lol
the stand is for my center speaker lol, its part of an old ironing board i harvested :D
I've always wondered - I have a PS3 and I love the controller, just not for certain games - is there any way you can mod a PS3 controller to fit inside the 360s?
So you could effectively have a 360 controller that works on a PS3 including tilt?
Yes, not easily though but the internals do fit.
