Great ATI Radeon 4800 Deals from OcUK on both Graphics Cards & Coolers/Heatsinks!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have some storming deals for you guys on 4800 series graphics cards and relevant cooling solutions:-
Gainward ATI Radeon HD 4850 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
The ATI Radeon HD 4800 Series GPUs bring the power of graphics ‘supercomputing’ to gamers, setting a new standard for visual computing. Redefine the way you play and take HD gaming to the extreme with best-in-class performance. The new TeraScale graphics engine delivers an immersive, cinematic gaming experience. Add this GPU to your PC and watch Blu-ray movies and play HD content with incredible visual fidelity. Do it all with break-through efficiency that doesn’t compromise performance.
- ATI Radeon HD 4850 GPU @ 625MHz
- 512MB GDDR3 Memory @ 1986MHz
- 24x custom filter anti-aliasing (CFAA) and high performance anisotropic filtering
- PCI Express 2.0 support
- 256-bit GDDR3 memory interface
- ATI CrossFireX Multi-GPU Technology
- Microsoft DirectX 10.1 support
- Shader Model 4.1
- ATI Avivo HD video and display technology
- Unified Video Decoder 2 (UVD) for Blu-ray and HD Video
- Built-in HDMI with 5.1 surround sound support
- On-chip HDCP
Price: £94.99+VAT (£111.61 Inc. VAT)
BUY NOW!
Gainward ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
- ATI Radeon HD 4870 GPU @ 750MHz
- 512MB GDDR5 Memory @ 3600MHz
- Shader Model 4.1
- On-chip HDCP
Price: £144.99+VAT (£170.36 Inc. VAT)
BUY NOW!
Gigabyte ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
- Shader Model 4.1
- On-chip HDCP
Price: £153.99+VAT (£180.94 Inc. VAT)
BUY NOW!
Powercolor ATI Radeon HD 4850 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
- Shader Model 4.1
- On-chip HDCP
Price: £98.99+VAT (£116.31 Inc. VAT)
BUY NOW!
Powercolor ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
- Shader Model 4.1
- On-chip HDCP
Price: £148.99+VAT (£175.06 Inc. VAT)
BUY NOW!
Arctic Cooling Accelero S1 Rev. 2 VGA Cooler
The Accelero S1 features 4 thick copper heatpipes which connect directly from the GPU core. The heatpipes with sintered powder wicks provide ultimate heat conductivity. Heat from the GPU is rapidly dissipated through 32 fins that extend beyond the height of the graphic card. Optimized fin design allows better air flow thus removing the heat more effectively. Together with the bundled RAM heatsinks and voltage regulator heat spreader, Accelero S1 provides an all-round passive solution that achieves the best cooling performance.
- Supports: ATI X1950, X1900, X1800, Nvidia 7950, 7900, 7800, 6800 Series, 8800GT (Requires VRM Heatsinks) & 8800GTS(G92)
- Noiseless Cooling
- 4 Heat Pipes
- Special Heat Spreader for Voltage Regulator Cooling
- Memory Cooling
- High Reliability
- Low Weight
- 6 Years Warranty
Price: £10.99+VAT (£12.91 Inc. VAT)
BUY NOW!
Akasa AK-VC03-BLUV Vortexx NEO VGA Cooler
Vortexx Neo is a new VGA cooler designed for hi-performance, low noise and stunning looks. It is a perfect upgrade for noisy and boring stock coolers.
Two long U-shape copper heatpipes help to transfer the heat from the large 62 x 62mm copper base to 33 bonded aluminium fine fins. A solid aluminium plate with a surface area of 45cm removes the heat from the RAM chips. Thanks to the smart airflow, Vortexx Neo provides high thermal performance with much improved acoustic levels. An akasa design 80mm lo-noise fan draws cool air from the case through the coolers fins and exhausts the heated air out of the case rear panel. The innovative design directs some of the airflow to cool board components including the VGA voltage regulators, it is crucial for graphics performance and stability to keep these components within thermal operating parameters. VORTEXX Neo is SLI and CrossFire compatible and is designed to optimize the performance of NVIDIA and ATI VGA hi- end cards. It has an acoustic performance at 2500 RPM of 0.475 Sone, whilst delivering an incredible cooling performance of 0.36ºC/W, most stock VGA coolers can only approach that thermal level at 4500 RPM fan speed which produces much more noise.
- ATI & NVIDIA compatible
- Lo-noise fan
- Easy tool-free installation
- 2 copper heatpipes
- large copper base
- Cools GPU, VGA RAM and VRM’s
- Standard 3 pin Motherboard connector
- SLI & CrossFire ready
Price: £14.99+VAT (£17.61 Inc. VAT)
BUY NOW!
Thermaltake DuOrb VGA Cooler
The Thermaltake DuOrb VGA Cooler features an all copper cooling system with a Dual-Orb design. Each Orb of the cooler utilizes a heat pipe to connect the base to its copper fins and two 80x15mm Scurve blade fans to drive the air. The DuOrb provides compatibility with the latest nVIDIA and ATI graphics cards on the market today, with easy universal installation.
- Dimensions: 180.5mm x 98.5mm x 30mm
- Fan Dimensions: 80mm x 80mm x 15mm
- Fan Connector: 4-Pin
- Fan Speed: 2500 RPM
- Airflow: 23.8 CFM
Compatibility:
Nvidia 8800GT/GTS/GTX/Ultra
Nvidia 7900 GTX
Nvidia 7800 GT/GTX
Nvidia 6800 GS/GT
ATI X1950 PRO/XT/XTX
ATI X1900 GT/XT/XTX
ATI X1800 GTO/XL/XT
ATI HD3870
Price: £19.99+VAT (£23.49 Inc. VAT)
BUY NOW!
Zalman VF1000-LED VGA Cooler
The Zalman VF1000-LED is equipped with Zalman’s patented VFP (Variable Fin Profile) technology. The 80mm slim LED fan is installed inside the heatsink to maximize cooling efficiency and the product’s maximized dissipation surface area provides excellent performance. Use of four high performance heatpipes maximizes heat transfer. The newly improved installation structure provides easy installation and broad compatibility with most graphics cards. An adjustable fan speed controller (Fan Mate 2) enables control of noise and fan speed.
Price: £22.99+VAT (£27.01 Inc. VAT)
BUY NOW!
Zalman ZM-RHS1 Silent VGA RAM Heatsink Kit
These eight little pieces of aluminium are designed for video card RAM chips, they help to dissipate the heat generated by the RAM. They are extremely light and offer excellent heat transfer properties. The heatsinks are compatible with virtually all VGA RAM, measuring 12 x 12 mm. Installation is very straightforward, just remove the backing from the base of the heatsink and press it onto the RAM chip.
Price: £4.99+VAT (£5.86 Inc. VAT)
BUY NOW!
All of the above coolers are compatible with the 4850/4870 graphics cards and everything is reduced in price until end of this month.
NOTE: - Modification of your graphics card does invalidate your warranty both with OcUK and the manufacturer, so proceed at your own risk.
must resist, must resist, must resist.
Promised myself that I'd wait until the end of Aug and get a minimum of the 4870 1GB and look at whether the X2 was worth it. But wow, £170 is making it v.hard to resist just plumping for a 4870 now.
yewen
ive changed cpu coolers etc
but how would 1 go about changing a vga cooler?
pretty similar tbh, just more screws. :D
Unscrew the old one, remove it, clean up chips, reapply TIM, screw the new one on. Stick on some ram sinks.
I find CPU coolers scarier/hard to do tbh as they can be a pain with one pair of hands, quiet often in a cramped case and the pressure needed can be pain sometimes.
Stripping down a card just seems easier a lot of the time.
yewen
About 12 screws off the 4870 cooler, then fit the new one is just 4 screws on the Vortexx.
that vortex looks the dogs danglies :cool:
It is!
I have one, used one on a high end rig, Gibbo has one (yet to fit, he needs to do it tonight!) and a fair few of our technical department either have them or are considering the purchase for their crossfire setups.
You would not guess that we rate them would you, halved the idle temperature on the 4870 that I did and the load never went above the stock idle. The card was fully driver clocked in the ATI driver. :)
Would it be better to get two of those cheap 4850's or 1 4870 at 1920x1200?
Do most new games support crossfire?
