What about SSAA, can they do that?
Yes, but using shader power, which obviously takes away from general GPU performance significantly.
This is the problem for 8800GTX users, these cards just don't offer big improvements in the games that matter and in the games they do, the extra performance was never really needed, like COD4 for example.
The only card thats going to really provide an improvment big enough to impress is a GTX280 or 9800GX2.
I just don't like the idea of the 280.....too hot,
It's not that hot, mine loads at around 75-80C at load in Crysis and at idle around 45C, allot better then my 8800GTX which really does output allot of heat, it's actually cooler then the 8800GTX, 9800GX2, 4870 and 4850.
But still users like to stread allot of fud about the GTX280, and allot of users tend to beleive it without ever trying one for themselfs.
Has the custom AA changed on the 4800 series because i can do 32xAA on the 3870's.
Not sure myself. 24x was all I could see in CCC (4850 of course), that was changing the drop down to "big tent" or whatever the highest option is, that gave the slider a max postision of 24x. I think I have also seen it quoted as 24x in specs.
I do not know my way round CCC at all of course.
If you've tested 32x on the 3870 (approx the equiv of what? an 8800GTS?), what's it like? Total slideshow? does it depend on the game (like the 8800GTX I have depends.....some games are still pulling in and around 60fps with it at 32x at 1920x1200, others simply fill their undies and do 0.2FPS), or does it fly along with minimal impact, in support of the general opinion that ATI's take a significantly smaller FPS hit with high AA (not withstanding my previous comments that some folks think 4x is high and 8x is pointless).
Is this two 3870's in xfire? Seen mention that 2xNv's in SLI can combine AA and give 64x, might be the 3870 only does 16 when left on it's own (implying that 2x4870's could do 48x Wooohooo).
I SERIOUSLY appreciate all your help and advice here, all of you. I'm just trying to avoid slinging 2-300 quid on a card that will be worse or no better than what I have.
Ill do some playing at 1920xx1200 & i totally agree with you that some racing games need more AA than other types of games.
Edit: just disabled Crossfire & CCC is only showing X24 AA max.
That's interesting.
I take it the power consumption figures are nonsense as well then?
(obviously if it draws 1.5-2 times the power of the GTX is must output that much more heat).
I know the core temp's nothing to worry about, it was just the amount of heat it creates overall I was on about, I should have been more specific.
Better cooler, I have a 120mm fan sucking air out above the PCIe slot, the 8800GTX dumps allot more heat into your case then a GTX280 does.
