Upgrading my machine, what do i need ?
20 Nov 2006
Well ive got an unlimited budget but i dont want to spend a fortune if i dont have to. I want to upgrade my machine and this is what i have atm;
CPU: Q6600 GO
MBO: Gigabyte DSR3
RAM: Crucial Balistix 5300 DDR2
GFX: 8800GTX
PSU: Corsair 650w
So what do i need to bring me up to date ?
Thanks.
CPU: Q6600 GO
MBO: Gigabyte DSR3
GFX: 8800GTX
PSU: Corsair 650w
Thanks.
nothing.. thats still a good system
As platinum87 says that is a good system, what does it not do that you want it to? There are a few changes you could make but most will probably not offer a performance benefit in line with the cost.
Have you tried overclocking yet? And how much Ram do you have? Those are the two cheapest areas to try for increased speed.
It wont be cost effective, but you could improve on the Q6600 by getting the newer Quads, like the Q9450. You could swap your GTX for a ATi 4870, and you could bump your ram up to PC8500. I don't really know what your current system couldnt run though, apart from the obvious ;)
Unless you haven't yet overclocked your system, I would just leave it as it is. There is nothing wrong with it at the moment, and it still runs with the higher end systems around today.
2 GB of ram atm, i was looking at upgrading the GFX card mainly because of the new chipsets.
I'd consider 4gb of PC6400 and overclocking since it is relatively cheap at ~£60 for the Ram and ~£30 for a good cooler (if you don't already have one), this should give you a fair bit of a boost. The Ram would be especially handy if you are on Vista.
