Spray detailer is a lube and a pre-wax cleanser
You can lube using it when claybaring then when your claybar is all used up use *** spray for after wash pre-wax finishing before applying the wax
Soapy water can be used instead for claybarring but the spray was made for it so would be a better choice!
