- 19 Oct 2002
- Torbay, Devon, UK
Found him
z0mbi3 is the correct spelling.
Hutch,
It's on til at least the end of this month the bt line offer
You have to call up, (look for bt's number etc) or just use main one and play press the keypad until you're at new customer/line etc
Don't think it's advertised openly you really have to dig deep on the site
You sign an 18mth contract instead of 12mth, that's only difference
Hope that helps
If needed and you can't get a number i'll try and find the one i used to call
Hi, thanks for advice. I am enabled for BE although i live about 1k away from the exchange, is that good or bad?
is the cable 1km long, or are you 1km away (im terms of direct distance), because the cable could be 5km long because they have routed it like a bunch of monkeys would
