D600 screen hinges, feeling a bit loose/wobbly can i tighten them? or replace only..
Don
21 Oct 2002
Parts Unknown
as title
can be bought for about £15 from the bay, never really looked at laptop screen hinges before, is it just a case of tightening a screw, or would i need a new set.
(currently, the screen has about 5-10mm of free/flappy movement
cheers
bledd
i could just be the screws need nipping up either where it goes into the base, or the back cabinet, you can get to the back ones by taking the bezel off, or it could be the hinges which are not too difficult if your patient.
done these ones
feeling a lot better, how do i get to the others? (and done the one on the right obv)
if you take the screw out of the lcd bezel hidden under the rubber screw caps, left and right the hinges are screwed to the back plastics, these can work loose also, you might have to do the top bezel scews as well to avoid stressing and snapping the bezel.
edit also do the base screws near the back will stop any flexing.
cheers,
it's more than acceptable now, doesn't shake after i've let it go, and doesn't wobble at all when typing :)
love this laptop, managed to get one with the nice screen, 14.1" @ 1400x1050 rocks, battery life is unreal on it
have got two moludlar bay batteries and two normal batteries, can get around 14hours battery out of it without having to turn it off once :D (brightness right down, and not using speakers)
plus, the modular bay can take a hard drive if you wish :)
can this take 1gb sticks anyone know? it's dead snappy with 1gb (12 processes running), but if i can get 2gb, then all the merrier
a quick investigation reveals the following about £40 a stick though:eek:
Dell Latitude D600 Memory
Latitude D600
Maximum Memory 2GB
Memory Slots 2 (2 banks of 1)
non-removable base memory 0MB
Machine name: Dell Latitude D600
CPU options: Intel Pentium M
Chipset: Intel 855PM Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2700 DDR333 200pin SDRAM SODIMM
Special notes:
yeah will take take 2 x 1gig sticks but no point as memory is pricey for this model and vista will still run like a dog, i find 1gig is ample on this model with xp, infact 512 runs nice, vista is a no go with the cpu
Vista ran fine on my D600 with 2Gb in it. Only problem was it didn't run aero.
