Crysis - Tamed. C.U.D.A.A.T.S [CCC] v2.21
26 Dec 2005
Paisley
New config file for Crysis with incredible speed boosts.
http://www.incrysis.com/forums/viewtopic.php?id=23117
Features:
-Allows the user to select DX9.0 or DX10 Configuration files;
-Allows the user to select a Configuration file according to their computer's performance;
-Injects UltimaRage's Time of Day modification, if selected;
-Allows the user to add Doomlord or Assassin's AI Tweaks.
-Optimized code.
-Fixed compatibility issues on Windows Vista machines, with UAC enabled.
-Allows user to revert the installation completely, without having to back up their entire Crysis folder.
Whats level 5? Equivilant to high?
Hmmm, says Ultra is needed for Lvl6, would not even use an Ultra for that..
the game looks pretty out of the box
it takes 4 hours to complete
multiplayer sucks
no replay value
why do people bother modding it?
Farcry was a much better game imo
multiplayer sucks
no replay value
If you havent got anything positive to add to the thread, perhaps you shouldnt bother post, rather than trolling for a response. :rolleyes:
Some people dont think Crysis looks pretty out of the box, the fact you can make it look a hell of a lot better with like no performance difference speaks for itself.
It took me 8 hours to complete, and it wouls take longer if you explored, 4 hours yes thats just flying through the game.
Now some of the game was very crap, like as soon as you entered the space ship it went downhill for me, sure was some nice effects, but it still went downhill.
I'll try this later, I wish I kept my CFG I used, gave the best performance for me, looks amazing and ran smooth.
i almost quit playing it because of that, stupid pointless level where you can tell they've tried to 'wow' you, but failed :(
Ok, here is a screenshot, bit dissapointed, dont look that good.
That is with 4xAA enabled, crapp in game AA, 35fps, without its about 38-40fps.
1680x1050, 4xAA, scaled down to 1024x640.
Ok this installer has mucked my crysis install up, I mean not I'm on 1680x1050, all high apart from shadows and PP and I'm getting 57fps?? Does that look like high apart from shadows and PP to you?
Uninstalled the mod, thats just standard high with shadows on medium and PP on medium which makes little difference usually.
i think similer mod/config was already done long time ago does not seem to improve frames tbh.
but it gives u more visiual/better graphics at the same framerates
that was the best bit
it was like forsaken or decent
not some generic shooter like it is up until that point
Level 6:
All these cfg's look crap, unless its my ATi card, going to have to try some other ones.
They dont look as crap in the screenies, but jaggies are worse, you've got uber bluryness in the distance like no AF.
Well I guess not many people are interested in Crymark anymore.
Anyway I'll post some cfg's here, these are better than the mod packs imo.
con_restricted=0
r_displayinfo=1
r_VSync=1
d3d9_TripleBuffering=1
r_ssao_quality=1
r_ssao_amount=0.2
r_SSAO_darkening=3.6
r_TerrainAO_FadeDist=1
r_HDRlevel=0.5
r_TexturesStreaming=0
r_ColorGradingDOF=0
r_ShadowJittering=1
r_ShadowBlur=0
r_GetScreenshot=1
r_GeomInstancing=1
r_MotionBlur=3
r_sunshafts 1
e_hw_occlusion_culling_object=1
e_gsm_lods_num=4
e_shadows_from_terrain_in_all_lods=0
r_UseEdgeAA=2
e_shadows_max_texture_size=512
e_view_dist_ratio=45
e_particles_lod=0.7
e_vegetation_min_size=1.5
e_view_dist_ratio_vegetation=50
q_ShaderShadow=1
r_EyeAdaptationBase=0.2
Aaaand one I used to use:
r_displayinfo=0
con_restricted=0
e_water_ocean_fft
r_ssao_quality=1
r_ssao_amount=0.2
r_HDRlevel=0.75
r_UseEdgeAA=2
Screenshot of the one in the first quote:
4xAA enabled, 1680x1050.
