- 26 Dec 2005
- Paisley
New config file for Crysis with incredible speed boosts.
http://www.incrysis.com/forums/viewtopic.php?id=23117
C.U.D.A.A.T.S [CCC] v2.21
Features:
-Allows the user to select DX9.0 or DX10 Configuration files;
-Allows the user to select a Configuration file according to their computer's performance;
-Injects UltimaRage's Time of Day modification, if selected;
-Allows the user to add Doomlord or Assassin's AI Tweaks.
-Optimized code.
-Fixed compatibility issues on Windows Vista machines, with UAC enabled.
-Allows user to revert the installation completely, without having to back up their entire Crysis folder.
Features:
-Optimized code.
