Yeah... Intel already had issues with the manufacturing process and now use "high-k" materials for.... something.
Anyway, It'll be interesting to see if the GPU market uses something similar.
I'm sure with the current materials being used we'll be able to get to 12nm - after that I'm a bit dubious.
What's the most fun part is that althought everything is shrinking in size - actually it is getting bigger. I'm pretty sure the RV9xx series even tho probably being 32nm or less, will need at least a full tower case to fit in, mid towers just wont cut it anymore soon, they already have problems
.Same goes for CPUs, the new nehalems will be bigger, the mobos will be bigger, the CPU coolers will be bigger - anyone that has seen scythe orochi knows what I have in mind
