Permabanned
- 22 Aug 2004
Alright, so I should just do 3x8 of the maximum weight I can manage, until I can do more and then increase the weight? I was just checking because I read about some sort of bodyweight:weights ratio that you're supposed to follow...
not UNTIL you can do more always PUSH to do more. Use a load that is difficult to do 3x8. Then, providing you managed 3x8 the last time, use heavier weights and try 3x8 until you get to a point that you cant do 3x8 with good form. Keep trying this weight to see if you improve. If you dont you may need to try one of the following methods
1) use a heavier weight for less reps for a few sessions
2) Upon failure cheat the rep or get assistance from a spotter
3)Do the negative portion of the rep only with heavily assisted positive
4)Drop the reps significantly and do very heavy strength training for a few weeks.
Then try again
Imagine trying to get it back on the rack!
