Does rain kill electric stuff?
Man of Honour
17 Oct 2002
I left my garage door remote outside. It then rained more than its ever rained ever before. It now doesn't work.
Is there some sort of way of rescuing electrical devices from the rain? :/
If it doesn't work then it's possibly dead. Also with things like remote controls chances are it's messed up the battery - so you might need to just replace it.
If it doesn't have moving parts - then try sticking it in the airing cupboard for a bit and seeing if that works.
It'll most likely be some sort of electrical conductive deposit shorting some contacts from the water evaporating. Open it up and see if there's anything obvious.
Burnsy
I've taken it to bits and put it in the airing cupboard. The light comes on but... it doesnt open the door. Which suggests it isnt the battery its something else :(
I've taken the battery out now but when I was testing it the battery was still in. Red light came on but.. nothing else happened.
Uh oh.
Do you still have the garage door? Nobody steal it during the night?
read the manual and see if it can lose it's code and se if it tells you how to put it back in.
Or it could have shorted some component and fried it.
If all else fails, try and get some pure water with no minerals in. Wash the remote, hopefully it should wash away the conductive bits left by the rain....
Leave to dry, then try again...
You jest? This is some satire on the inanity of the questions being asked in GD all too frequently, surely?
If people are now permitted to ask GD which sandwich filling is best then I can ask the worldly wise for advice on water damaged electricals. I'm not an expert on water damaged electronics but who knows, someone on here might be.
