http://joshuathomsonphotography.weebly.com/index.html
I know I posted this before, but I've totally revamped it since then.
Thanks
Thanks
Your writing is pathetic.
Sorry, I don't like it, there's no imagination whatsoever in the design.
The design is kept simple not to draw the focus from the pictures. I think it works well. The writing is ok for a 16 year old
I also think your photography is very good
Navigation between images could be a bit easier, im having to clock back quite a bit.
As said (rather rudely imo) your writing could do with being a touch more professional, also i dont think your signature is nessesary unless your the owner of a large company.
Josh it's clean and simple but may not showcase your photographs to their best. However, as it's essentially free using weebly I reckon it's a decent enough effort. you may wish in future to get your own domain name and hosting and construct a more bespoke solution, but obviously the cost will be much higher. The signature *could* be used in identity fraud though, so may be wise to remove it if you're worried about security stuff like that. My advice is get your S9600, take some more original shots, maybe some abstract stuff or macros, look at post processing and maybe changing shots to increase the scope of your portfolio and enjoy!
Have you looked at redbubble etc. to sell stuff if that's the way you want to go?
Also, you can get a free flickr account to increase the visibility of your work, just watch out for the freeloaders nicking your stuff![]()
I'm sure that lightbox or whatever script you use to overlay the images can use a next and previous button type navigation, that will ease it a bit...
The signature thing is just a possibility - perhaps I'm paranoid (call me Marvin) but if it's not your usual signature then what's the worry!?!?!?
Regarding the showcase, what I'm trying to get at is I'm not sure that there are many real standout images there yet. Just a little critique, I see many portfolios or galleries with "standard" shots. Don't worry about putting some different shots, get your S9600 and try out different ideas...
its a good start mate
i think your pics should be larger in order to make more of an impact
the title bar is a little plain
keeping a simple font - but perhaps jazzing that up - as it was the first thing i looked at
It's not bad, but the white space at the bottom bugs me a lot. Either move the grey footer bar to the bottom or extend it to the bottom.
