do the game installs save or is it just the save games?
You can back everything up inc. installs.
<phew>....
All done and dusted now.
Not really as easy as the guides and youtube vids made out, but anyone with half a brain should manage.
Firstly, the 40gb PS3's drive caddy goes straight into the PS3 and not sideways.
Secondly, you need to set yourself up with a temporary account before you reformat the new hdd.
Thirdly, you need to reinstall the latest firmware so make sure you have that handy. Then you can restore your normal account.
Ummm.... fourthly, you need to reactivate your PS3 in account management so you can play all the games you've previously downloaded and restored. (I had to do that twice as it didn't work the 1st time)
Other than that, smooth sailing, apart from the 5 tightest screws I have ever encountered and one I almost stripped
Still.... I now have a 250gb PS3 so I don't care![]()
Perhaps the 40gb PS3 is a little different ?
After all, the drive orientation was different, maybe other stuff was too ?![]()
Hmmmm.... odd !!
Well, at least I don't have to do it again. I'm all warm and snuggly with my 250gb![]()
It's been said te 60gb model runs a little warmer so if you get the kit that allows you to use a 3.5" externally will that make the system a heck of a lot cooler?
The real chrome finish does look lovely though.
I have to agree, not only do i hate the silver finish on my 40gig, i detest the fact that it's wearing off on one of the corners, its just silver paint on black plastic damn it!
...For future reference don't bother backing up to the hdd that you intend to install.
