- 27 Jul 2005
- The Orion Spur
yeah thats the lot matey sway ya HD over![]()
cheers bud, gonna install the new hdd now, scary stuff
cheers bud, gonna install the new hdd now, scary stuff, just hope it all works.![]()
Its very easy,BUT be careful the 4 screws that hold the HD in the caddy ,they round of very,very easy.Get yourself a pair of fine pointed pliers to help loosen the screws if you have any problems.
Yeah those screws were a bit of a bugger tbh, lucky I found a Phillips screwdriver that was a real snug fit, used an old cloth on the screwdrivers handle to give me a bit of extra grip and they eventually cracked lose, anyway, the new drive is in now and I've just started of the process of restoring the system using my backup, I was a bit surprised to see my user name and profiles/friends on the XMB after I put the new drive in, I guess that data is saved on the PS3's firmware, anyway thanks for your help mate.
Free Space 404GB / 465GB
Would I be able to recover some space if I did a full format? I only did a quick format as it wanted 28 hours to do a full one!
