I went for a Honda mower as the VTEC is essential for keeping the grass under control.
Hope your lawns not on a slope, no chance of getting up there if it is!
Follow guide, it's probably 2 stroke petrol/oil mix.
Do not forget those bhp booster magnets, you could cut 500 more blades of grass in 0.1 of a second.
Don't forgot the screw mod.Personally I'd spend the cash on a resistor of justice.
Surely if you really care about your mower you'd only consider this stuff?
Yep forgot that one. I was going to suggest a K&N Induction Cone except the heat soak issue isn't worth the hassle really.Guys you haven't advised him of the ecotek valve to fit near the brake servo. It disturbs the airflow and helps increase the horsepower, from about 4-6hp.......
6HP, CAN YOU IMAGINE THE POWER, but watch out otherwise your wheels will spin in all gears up to 3rd.
By the way, what sort of economy are you lads getting out of your mowers? And anyone know any good mods for a petrol strimmer? Can you screw mod it?
I run mine on alcohol and N2O.
