Put it this way, it was written off and he repaired it himself. It was quite a hefty bit of work iirc.
Better to keep this one than suffer the part-X hit from a written of car?
VX220 and Elises that are written off are very different to normal cars that are written off.
Just cracking the clamshell on a Vx220 can write them off
I need to put a boost gauge in my car and would like an oil pressure gauge too. Elise-shop.com do quite a nice pod for either two or three gauges and they also sell the gauges themselves for oil temp, oil pressure and boost. Are there any better options than this or any multifunction devices which are capable of doing the same and more?
Check out SPA guages.
Very good bits of kit
Surprised you're letting some company use your car as a guinea pig![]()
I'm definitely interested in how this goes for when i maybe/hopefully/really need to/going to do it/sort my priorities out/get a vx lol.
Are they aiming to make it significantly cheaper by doing a DIY install? Will you need an aftermarket ECU for the mapping and additional sensors? What superchargers can you get from courtenay at the moment?
