Hey all,
Looking at expanding capabilties of my kit, and beefing up the sound some what for live performances, im looking at some drum triggers, no heres my beef!
If i take each signal from the drum trigger and send them into a Trigger to MIDI converter which converter should i buy? then can i take the MIDI signal, and Transfer MIDI > USB, into my Macbook Pro into Logic 8, into a Drum Module (EzDrummer, or Similar) then take the signal out of the mac, straight into the PA.
Doable?
-Neoni
P.s - whys my avatar a drumkit?
Doable?
-Neoni
