[TW]Fox;12345872 said:No it's not - but it's easier to say 'you must have projectors' because in terms of retrofitting, this is 100% true.
But they have modified, specially designed reflector setups which counteract any beam scatter. A halogen fitted car WONT have these, so for all intents and purposes this is irrelevent - if you want to retrofit Xenons you need projectors, if you've got suitable reflectors you will also already have Xenons from the factory, making this irrelevent.
Not all projector lenses are approved for xenon lights though, if you take your attitude to it any approved projector lens would already have xenons fitted. Take for instance your E39 the light unit for a xenon equiped E39 is totally different to the light unit you have fitted a HID kit to, even though its a projector unit.
